Toshiba e 600 change logic board
  • SOS
    • Oct 2011
    • 46
    Hello new friends,
    i changed new logic board, and now total counter meter reading different, old meter only 200k and now with new logic 400k, how can i change back to 200k.
    Thank you very much
  • emujo
    • Jun 2009
    • 3009
    Re: Toshiba e 600 change logic board
    Follow the procedure in the service handbook (08/257). You could also try putting the original NVRAM back on the newer board (but 08 257 should correct this). Happens because the counter values are stored on 2 different bds and you must have salvaged an old board. Emujo
    • SOS
      • Oct 2011
      • 46
      hello emujo,
      thank you very much for your support, but i been try 08/257 tranfer back nv ram, and total count still show 400k.
      • jamesyboy
        toner monkey
        • Jul 2010
        • 188
        did you change the eprom with the board if the eprom is from another machine it will have that value stored from previous fit the original eprom from youre machine
        • arnh79
          • 468
          Let's hear it for roofing contractors! Who knew they had such a keen interest in Toshiba copiers? Wonders never cease.
          Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
          • emujo
            • Jun 2009
            • 3009
            If your roof leaks..water gets into copier..must be preventive maintenance. Emujo
            • emujo
              • Jun 2009
              • 3009
              Originally posted by SOS
              hello emujo,
              Sound like you may have wrote the contents of the LGC bd back to the SLG bd instead of vice versa. You could try to put the old LGC bd back in just to transfer meter count back to SLG..Procedure is 08/257..1 or 2. Did you follow the manual, or just guess? Emujo
