not printing pdf files
  • digicor
    • Jul 2008
    • 1159
    i have now two as of today toshiba estudios not printing pdf files, one is 202l and the other 281c, they will print word docs but not pdf... if you send a lrge pdf it will prnt the first two pages then just go into cyberspace like its spooling the document??? one wont even spit out the first two pages. i have replaced the driver's, no fixy,anybody know what gives? and by the way they were printing just fine for months.
  • nmfaxman
    • 1702
    Re: not printing pdf files
    Click Print as image when driver box comes up.
    • arnh79
      • 468
      Are you using the PS3 driver or PCL6? We have nothing but problems when we use the PS driver to print pdf's. I've seen it work for a while and then when Adobe does an update the PS driver starts acting up. We now only load the PCL6 driver on customers machines.
      Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • emujo
        • Jun 2009
        • 3009
        also, in Toshiba world, frequently the drivers are matched to a firmware update. This means you should get the MFP to the correct firmware level before trying to utilize the newer drivers. The PDF file is probably generating a Post Script error and causing the lock up. Print as image (previous post) is a really good workaround for these types of issues. EMujo
        • jamesyboy
          toner monkey
          • Jul 2010
          • 188
          had similar issues
          if its ps try switching off the post script options
          if pcl enable direct printing
          cloud printings on its way should be fun !!!!
          • digicor
            • Jul 2008
            • 1159
            all good ideas and info, thanks
              • 8214
              On the Other Tab in the PSL3 Driver is PosrScript Options, uncheck PostScript PassThrough only.
              What Version of Adobe PDF Reader are you using?
              What Version of firmware is the e281c at? Should be V354.
              What Version of Print Driver are you using? Should be V4.5.79.0.
              Load both PCL6 & PSL3 drivers and test.
              Change Port from RAW to LPR.
              LPR Print Queue Name: print
              Uncheck LPR Byte Counting and SNMP Status
              • digicor
                • Jul 2008
                • 1159
                ok ive re drivered the thing with a plc6 lates version pdf's fly out but not in color!! ive tried all the settings in the print preferences, properties, and the default in the machine, still no color, is there a fix or patch or something else to fix this in the e studio281c/451c???? thanks for the advice.
                • emujo
                  • Jun 2009
                  • 3009
                  Did you inadvertantly download the PCL6 driver? Only supports B&W....Emujo
                  • digicor
                    • Jul 2008
                    • 1159
                    it was the driver on the toshiba site color copier/universal e bridge driver for 451c,,
                    is there another place to download this? i have been downloading from there site for all my toshiba drivers,
                    any other place to get it?the software that comes with these machines is outdated. thanks for any help.
                    • emujo
                      • Jun 2009
                      • 3009
                      FYI.Toshiba.com
                      Either the 451C PS, or the PCL5eC. Don't use the univ driver unless you have to..ie no Win7 driver. Emujo
