E-studio 350
  • elcondor
    • Aug 2025
    E-studio 350
    the machine give code c 970 continuous
    i change the main and transfer charger terminals but go on the machine give this code...
  • mhmsaqer
    field Supervisor
    • Jun 2007
    • 83
    C970 High voltage leakage.
    check the the main charger & the transfer chargers for shorts.
    good luck
    Be happy for a moment - this moment is your life.
    Omar Khayyam
    • tech1224
      I have had this issue on all of my 350 & 450's. The way fixed this was useing a spacer of some type to put between the main charge holder and the track. what happens is the guide slides toward the grid. but also check the transfer seperation charge block for small cracks. and there is aldo a modification that just came out about a month ago for this. But since I have taken the steps listed the issues have't returned.
      • nhatthuc0000
        • Dec 2007
        • 44
        away other, you try to paste one film thin in the main charge holder.
        good luck
        Good luck to you!
        • jawir
          • Aug 2007
          • 107
          Hi all,
          My suggestion,
          after you have finished with the problem C970. do not forget always to clear the counter of charger in PM support mode when you replace the wire. If you don't, every time counter of charger count up than the more higher charge will increase. wire will vibrate/shake more stronger. that's why the terminal or grid will lackage.
          thanks
          • atudorica
            • Oct 2007
            • 79
            C970
            There is an update from Toshiba - a stronger spring for charge wire.
            I had one mc with a defective drum. Replacing drum fix the problem.
