Hello,
I had a tech go out to this Toshiba that said empty used toner. He had ordered a used toner bag that did not do the trick! I went out their today to check for myself and cleaned the waste toner sensor and checked for power at the sensor, 5 volts present. checked the cleaning auger for binding and checked for an auger binding switch which I could not find, is there one? so is the bottle sensor the only thing that senses used toner presents? I also would like to be able to check the sensor through the I/O but I don't have a manual . Any suggestions would be helpful. Thanks
