developer is adhered to the drum (e-450).
  • mhmsaqer
    field Supervisor
    • Jun 2007
    • 83
    Dear all,
    Many of our Hudson (e-450,e-350) machine have a common problem, the developer is adhered to the drum & the output copies have a background and the Toner is everywhere in the machine.
    the toner bottle make only about 5-7k copies & the waste toner bottle is filled Almost every 5k
    New genuine drum, blade, developer, charge wires toner adjustment is in the range, DC bias is in range etc.
    My doubt is there some connection is disconnected.
    Had you encountered this problem in the field? Any solving idea might be helpful.
    Appreciate your help.
    Be happy for a moment - this moment is your life.
    Omar Khayyam
  • tsbservice
    Field tech
    • 8031
    Did you check ground spring(U shaped) under dev unit?
    Drum to dev unit distance( i mean ROLL-GUIDE's)?
    A saw many posts from you and looks like you're doing very good job, always provide feed back which is great.Good luck and i know you will keep us informed.
    • nilsonmorales
      are the spacer good?
      hi you chek the developer bias voltage
      and the developer adjusment when change it
      sorry my english is bad i am from el salvador
      i think that i have the service manual my mail is nilsonmorales@hotmail.com add to your msn
      • mhmsaqer
        field Supervisor
        • Jun 2007
        • 83
        Dear all,
        the developer bias is there ,i've tried to disconnect the developer bias & the output is different from what i alredy hve.
        disconnecting the transfer bias yeilds no picture.
        but whats strange is that connecting or disconnecting the seperation bias yeilds the same results.
        i've tried to make print outs "function list" and the result copies look like magnified with about 125% and the letters are distorted "not smooth"
        as you can see below.
        Omar Khayyam
        • DSallee
          Sharp, Ricoh, Lanier Tech
          • 27
          OOPS.... sorry... wrong machine... hehe
          I went to new post and thought this was a sharp machine problem.. sorry....
          Dave
          GFI Digital Inc, KC
          SHARP, RICOH, LANIER Tech
          • xcopytech
            • Aug 2006
            • 1794
            es350-450
            What kind of toner you use. OEM Toshiba or something else.
            Also have you check ATC sensor in developer assy.
            Have you maybe clean developer assy by vacuum cleaner. You know that vacuum cleaner can destroy ATC sensor.
            Also have you tried to adjust toner amount in developer assembly. 08 414
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              Check the dev ground spring (under the dev unit not the plug), the
              mag roller stand offs (plastic rollers) and the if any work was done on the fuser lately then check the drive gears. There are two that can be put on backwards which will change the speed of the fuser making the paper move too fast causing the image to strech a little.
              • mhmsaqer
                field Supervisor
                • Jun 2007
                • 83
                every thing is genuine in the machine(Toshiba parts)
                the whole process unit is working greatly on another machine (drum,blade,main charger,developer unit)
                the developer ground spring is connected to the developer base.
                the double-drive gear in the fuser unit is putted in the correct way.
                and fuser unit it self has been changed with a new one.
                but if you look carefully to the attached function list you can see that the letters is not to scale and the transfer quality is not good (letters are not solid).
                did any body have this deformed prints ever.
                Omar Khayyam
                • gokundrz
                  if the print not solid, try do manual tone up, go 05-201, let the machine run, notice the display on the top left corner the figures run, figures with a % behind, check if it fall between 235-245, within these figures it should be solid enough. if not increase the value with the up key on the touch panel, if all done still result the same, time to change the developer.
                  • nilsonmorales
                    try for the optic
                    could be the poligon motor mirros are dirty i dont know ,you clean?
                    • remrair
                      • Mar 2008
                      • 9
                      I had a similar problem, check the conecteur of the erase leed
                      • Wild Bill
                        • Jul 2005
                        • 774
                        Arching corona blocks. Wires may not be in the v slot and too much charge pulling dv. Drum ground. My two cents, good luck!
                        Izzy
                        • mhmsaqer
                          field Supervisor
                          • Jun 2007
                          • 83
                          Dear all,
                          it was not the erase leds too.
                          Omar Khayyam
                          • ivovb
                            • 695
                            As wild bill says did U check drum ground? (Do U use conductive grease for drum shaft GRS-KS660 P100-I8 eS35/45?)
                            What about bias tract - cables, connectors etc.
                            HVT leakage at chargers?
                            BR
                            I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
                            • mhmsaqer
                              field Supervisor
                              • Jun 2007
                              • 83
                              Dear sir,
                              i've some doubts about the drum ground,
                              how can you ensure that the drum ground is connected in a right way?.
                              Thanks.
                              Omar Khayyam
