toshiba e-studio 452 error c480
  • smiley
    • Aug 2008
    • 615
    good day guys i just change the upper fuser roller after i replaced it. it give this code i try to reset this code but nothing happens. guys pleased help me on this. pleased...
    there is no glory without sacrifice
  • CCS
    • 266
    Re: toshiba e-studio 452 error c480
    (C480) IGBT high temperature
    Check connection on IH board cooling fan
    Clear the status counter: Change the values "12" , "15" or "18" of the status counter (08-400) to "0"
    • canonbundy
      • Jun 2012
      • 607
      Make sure the IH Coil is correctly positioned in the Housing both ends of the Fuser also make sure the Thermistors are clean and in proper contact with the Roller, then reset the Error - 08-400 to 0.
