Hey guys I have an estudio 253 that a transfer blade is not cleaning at all. I am new to Toshiba and I cant sem to find the bulletin with the info that I need. Not sure if there is a new style blade or if there is a different way of adjusting pressure on it. Thanks in advanced for your time and help on this. You can also email me direct at abtd65@gmail.com.
estudio 523 transfer blade not cleaning
Re: estudio 523 transfer blade not cleaning
The trasnfer blade for this machine has been used for a while before the part number changed. The screws which hold it in place can not be changed as the are in in the housing of the frame. Have you changed the blade or/and looled insided the transfer belt unit. The belt can sometimes drift on these models. If my typing is off blame the pub
muchaelIt didn't say that I couldn't do it in the manual.
