E355 firmware failure HDD
  • tech07
    • Aug 2008
    • 410
    [Dead] E355 firmware failure HDD
    I have done hundreds of firmware updates. Maybe a thousand. Today I hit the brick wall. Fixed a copy quality issue and decided to check firmware version. It was very old. (103)..Already had 300/335 on my laptop, so I put the firmware on my usb and began download. It went all the way through but indicated the HDD part failed. I have seen this several times also. I simply download the HDD again alone.and everythig works. Not this time. The Hdd fail code is H00 ( other )..I tried earlier versions without success. Can anyone offer input???
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: E355 firmware failure HDD
    Is this a es355 and not an 356? Had some issues with the ebx machines giving strange faults due to the hard drive.
    It didn't say that I couldn't do it in the manual.
    • tech07
      • Aug 2008
      • 410
      Problem resolved.. I skipped trying to download firmware using port on front of copier. Downloading from rear usb port solved everything..
      • hoanphuc20033
        • Mar 2011
        • 38
        you to 0 8-690 pressing zero 2 or 3 c press the numbers 3 to make sure you hdd executable non
        01 if you ok check the firmware
        02 if you Lợi instead hdd Other
        MOVING SERVICE COMPANY LTD Emerald Buddha
        Address: 202 Tran Hung Dao Q1 TP HCM VIỆT NAM
        Expert: sales, leasing, salamanders provide copier parts warehouse.
        Tour: board repair resource, sys board, main board, board scan ...
        Expert: purchase, exchange, used copiers.
        Tel: (08) 54041727 - 0938877144-0976583422 Mr. NGHIỆP
        YM: tienphatngoc2011@yahoo.com / hoanphuc20033@yahoo.com
        GM: vannghiep25@gmail.com
        Westie: mayphotocopytienphatngoc.blogspot.com
        • emujo
          • Jun 2009
          • 3009
          Perfect, he chimes in with his "recommendation" after problem is solved. Big help here....Emujo
