e Studio 355 with a rather noticeable paper skew and jams
    • 23009
    This call started out with E010, E062, E065, and E140 jams. It wouldn't pass a single piece of paper from any of the trays. After cleaning all the feed and registration rollers, and the registration clutch, I got paper to pass from tray #1 only, and skewing ~35mm, and about 35mm early registration.
    After some investigating I eventually pulled the imaging unit and closed the door. I could see a 1/2 mm gap at the front of the registration rollers. To confirm, I positioned a piece of LT paper between the reg rollers and closed the door. It was gripped at the back, but very loose at the front. You can see that the plastic door bending, bowing 3mm at the center.
    My solution was to file out the rectangular cutout that captures the rubber registration roller shaft at the front. It gained me 1 1/2 mm, and solved both the jam and skew issue.
    Tray #2 still was uncooperative, Z-folding every page near the leading edge, and jamming E065. A quick loop adjustment 05-452-0 solved that problem.
    My concern is with how flexible the plastic right door is. I can't imagine that a replacement door would be much different. Has anyone worked on this, and what were your conclusions? =^..^=
  • Acme
    • Jan 2013
    • 155
    Re: e Studio 355 with a rather noticeable paper skew and jams
    Is the white strap broken?
      • 23009
      OMG! I'm so stupid.
      I spoke with the boss about swapping out the door. Then he asked that same question. Of course it's broken. What difference would that make? Apparently the end of the strap at the door does not swivel out of the way properly, blocking the door closing.
      Add that one to the database. =^..^=
      • sagar4
        • Dec 2012
        • 127
        It will jam and skew with that white strap broken. As that strap is attached to a spring in which it gives it a lot more tension on that door.
        OMG! I'm so stupid.
        "Broken again"
        • Mad_Coachman
          • 99
          I have seen that strap break many times, now I get rid of it BEFORE it breaks and the machines work fine without it and I don't get those skewed copy calls anymore.
          • sagar4
            • Dec 2012
            • 127
            Good Luck. As the machine gets more and more copies on it you will see.
            "Broken again"
            • Mad_Coachman
              • 99
              I will see what? Please enlighten me.
              • mckinley
                Chief Twiddler
                • Dec 2006
                • 150
                There's a modified strengthened strap for the door.
                If you remove & leave the broken strap, the machine will eventually end up with a bent duplex & a bent machine frame, if the front corner gets bent, the machine is a write off ( had this a few times now )
                Worst one i had the ADU was pointing towards the floor when you opened it.
                Regards.
                Happiness Is The Road.
