toshiba e studio 452 say machine information error
  • Riyadh hossain
    • Aug 2025
    it's copying . when I start with 0+8 it show machine information error plz help someone
    • 23010
    Re: toshiba e studio 452 say machine information error
    I'm guessing that you've been swapping around system boards, or logic boards, or maybe NVRAMs. My suggestion is to get the original NVRAMs in the machine, and read the section of the manual regarding replacing the specific board you've changed.
    This isn't 1990. You can't just swap around boards and expect to get a working machine. =^..^=
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      I have received that error when replacing a new board as well.
      You will need version 300 firmware and the latest firmware to fix this.
      1.Downgrade machine to Ver 300 firmware
      3.Perform 08-665
      4.Install current version firmware.
      6.Compare the two sets of lists and reset the codes that have changed from the first set.
      And you may have to do this 2-3 times to fix it.
      • emujo
        • Jun 2009
        • 3009
        Gee Mr Spock, that sure is a lot of steps, anyway to cut it down to just 1 or 2??? Better yet, can you tell me the super secret "fix everything" code?? Emujo
        • sdrawkcab
          Confused & Bewildered
          • Jun 2009
          • 317
          Use this...
          Some days, it's just not worth chewing through the restraints
          • Mr Spock
            • Aug 2006
            • 2064
            The super secret "fix" for this is to purchase a newer SUPPORTED machine......
