it's copying . when I start with 0+8 it show machine information error plz help someone
toshiba e studio 452 say machine information error
Tags: None
Re: toshiba e studio 452 say machine information error
I'm guessing that you've been swapping around system boards, or logic boards, or maybe NVRAMs. My suggestion is to get the original NVRAMs in the machine, and read the section of the manual regarding replacing the specific board you've changed.
This isn't 1990. You can't just swap around boards and expect to get a working machine. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
I have received that error when replacing a new board as well.
You will need version 300 firmware and the latest firmware to fix this.
1.Downgrade machine to Ver 300 firmware
3.Perform 08-665
4.Install current version firmware.
6.Compare the two sets of lists and reset the codes that have changed from the first set.
And you may have to do this 2-3 times to fix it.
And Star Trek was just a tv show...yeah right!Comment
Gee Mr Spock, that sure is a lot of steps, anyway to cut it down to just 1 or 2??? Better yet, can you tell me the super secret "fix everything" code?? EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
The super secret "fix" for this is to purchase a newer SUPPORTED machine......And Star Trek was just a tv show...yeah right!Comment
