e Studio 35 Add Toner
    • 22999
    I think I've figured it out, but I'd like some confirmation. Yeah. I know it's an old one.
    The way I figure it, the enduser has been ignoring the "Add Toner" indication. After the first couple times the enduser opens the door while the motor is still cycling. Since it's been interrupted mid-cycle, the toner cartridge receptacle isn't at home position. The cartridge can't mate with the drive coupler, and doesn't depress the plunger at the center of the toner receptacle, and it consequently doesn't drive.
    Alternatively, perhaps the screw head that puts pressure on the front end of the toner cartridge is mis-adjusted, and the cartridge is camming out of the receptacle.
    Of course I did it the hard way the first time. Once I got the toner bottle receptacle out and in my hand, I could manually rotate it to the home position (top-dead-center, like in the picture). I think, though, that if I had a 16" long tool to depress the plunger, then keyed the door, the toner bottle drive would home by itself. True? =^..^=
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    Re: e Studio 35 Add Toner
    Customer puts cart in 180 degress out of sink , or rotates it as they put it in.
    cart end up upside down so the hole lines up with a solid plastic wall.
    That was the usual issue, always great for a 300 mile round trip
    Aint seen one in about 3 years as we stopped working on them.
    Regards.
    Happiness Is The Road.
    • Jhonjon
      • Sep 2013
      • 208
      [ATTACH=CONFIG]26030[/ATTACH]
      Thanks' for sharing the information regarding this model series.
        • 22999
        ... Of course I did it the hard way the first time. Once I got the toner bottle receptacle out and in my hand, I could manually rotate it to the home position (top-dead-center, like in the picture). I think, though, that if I had a 16" long tool to depress the plunger, then keyed the door, the toner bottle drive would home by itself. True? =^..^=
        Would this work?
        • esam ramadan
          • 199
          go ahead
            • 22999
            Originally posted by esam ramadan
            go ahead
            That sounds like the sort of non-specific response I would give. I guess I deserve it.
            The reason I ask is that there is a microswitch that detects the rotation of the bottle. It may or may not prevent this from working. =^..^=
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              Sometimes it works, most not. There was a firmware update (not available anymore) that would fix the stopping point. Even with the firmware it was only 75% effective.
