Service message
  • scobo65
    • May 2012
    • 13
    Service message
    We have a Toshiba E-520 with a message,"Service Recommended for IQC"
    What is this and what procedures to take care of this. Thanks for any help.
    • 23010
    Re: Service message
    Are you sure that it isn't "Service Recommended for IPC"
    IPC = image process control. That's Toshiba for drum potential sensor for anybody else. It's either dirty or bad. Isn't it funny how this message never made it into the manual? =^..^=
    • laitang
      • Nov 2012
      • 627
      Re: Service message
      You need a service handbook for e-studio 520 v.16
      • scobo65
        • May 2012
        • 13
        Re: Service message
        Ok, Thanks
        • scobo65
          • May 2012
          • 13
          Re: Service message
          Thanks for the info. That helps.
          • dariel89
            • May 2014
            • 18
            Re: Service message
            IQC stands for Image Quality Control.
            You have to performed an image quality control enforcement
            service mode 05-290
            • buuluu
              • Apr 2014
              • 49
              Re: Service message
              It show the counter of Drum's life is near off. You can access 08 - 800 set to 0. Be careful the copy may be made darker. To be sure, you replace a new Drum and access 08 - 800 set to 0 or 08 - 252 set to 0. After that access 05- 200 do auto toner adjustment. After completed, 05 - 290 to process control. The machine will be ok. Good luck
              • Nalinda
                • Feb 2015
                • 2
                Re: Service message
                need to toshiba e studio 230 firmware Plzzzzzzzzzzzzzz
                nalindagos@gmail.com
