Toshiba es3530c c580
  • JVC
    • Jun 2011
    • 151
    Hello
    I have a strange one I think. I have an es3530c that works fine until it goes into energy save mode. When it comes out the machine pops a c580 code. The customer can turn the machine on and if it does not enter energy save it will work fine all day but if it ever goes into energy save it pops the code when it comes out. Unfortunately they do not want me to disable the energy save mode. Any thoughts?
  • laitang
    • Nov 2012
    • 627
    Re: Toshiba es3530c c580
    Check the setting of 08-1912:
    Finisher model switching setting value 0: MJ-1030, MJ-1031, 1: MJ-1101
    Check if the harness connecting the IPC board and the finisher controller PC board is disconnected or open circuited
      • 23009
      You could have a bad converter board. If you change it, be sure that the finisher and converter are at compatable firmware levels. =^..^=
