Toshiba 6520 Copier
  • RonMac
    • Oct 2008
    • 57
    [Error Code] Toshiba 6520 Copier
    I am getting an error code 449. Replaced the thermistors, reset 08400 many times, but still get error code. Any help appreciated. TY
    Ron
  • bigwul
    • Jun 2014
    • 60
    Re: Toshiba 6520 Copier
    Search C449 on this forum - you will find additional suggestions. One of them being to check the connectors etc. for bent / broken pins.
    Read the other posts....have you tried all they suggest?
    • Luther
      • May 2006
      • 682
      clean the IH coil contacts that contact the fuser
        • 23009
        Power can do this. Get out your power quality analyzer. =^..^=
        • RonMac
          • Oct 2008
          • 57
          Put new thermistors in; thermal fuses are good. TY for your suggestions. Ron
          • RonMac
            • Oct 2008
            • 57
            Will try that. TY. Ron
            • RonMac
              • Oct 2008
              • 57
              Ok thanks. Ron
              • sagar4
                • Dec 2012
                • 127
                Originally posted by RonMac
                Ok thanks. Ron
                Also I found two of my customers plug there copier into a 15 amp outlet with an adapter.
                "Broken again"
                • RonMac
                  • Oct 2008
                  • 57
                  Heat roller was bad; replaced full fuser unit. TY Ron
