crazy estudio 650
  • esam ramadan
    • 199
    crazy estudio 650
    it was work good i turn it off then i getout fuser unit to clean the claws and it refused to work again i dont hear or see any thing work what happend ? thaks
  • esam ramadan
    • 199
    any ideas guys
    • imaginGuru
      check
      Your HDD is not initializing, if not a tech, call one and save headaches.
      imaginguru.
      • deep
        • Jun 2008
        • 208
        Any error code?
        Kenny
        • mrfuser
          • 1611
          eStudio Dead
          Most likely blew a fuse on the power supply. Very common. Call a tech and he should be able to fix it fairly easily.
          Kelly
          • esam ramadan
            • 199
            by the way i'm a tech - the panel don't light up so theres no eror codes finaly thanks for replies
            • mckinley
              Chief Twiddler
              • Dec 2006
              • 150
              check the wiring harness for the thermistors, it may be trapped.
              especially around the connector. also, if you removed the fuser unit, make sure the connectors are correct on the IH coil board.
              but trapped thermistor wires will give you a dead machine.
              Happiness Is The Road.
              • esam ramadan
                • 199
                thank you
