e-studio 256SE ADI HDD to normal HDD
  • Thomas007
    • 49
    Hi everyone,
    Is their any other possible procedure that's not listed in the bulletins/service manual for putting a normal type SATA HDD drive in this machine? The correct procedure could not be followed as the last owner took the ADI HDD with them.
    Is the only option to get a new ADI HDD??? Surely their must be some work around for this..
    Thanks in advance
    SRAM clear - noting change...
    Thomas007
  • didi2005
    • May 2011
    • 401
    Re: e-studio 256SE ADI HDD to normal HDD
    Previously there is something able to do that by "wiping" SRAM...
      • 23006
      According to the manual, a new machine may come delivered with either a SATA drive or a ADI drive. If the machine came with a SATA drive you may install either type. If the machine has an ADI drive you must install an ADI replacement. =^..^=
      • Thomas007
        • 49
        Could someone send a copy of sramu of the copier without ADI hdd?
