Missing Paper Size icon
  • Valintine
    • Jan 2012
    • 147
    Hello
    I have a Toshiba es4520c that is missing the paper size indicator in the user functions section. I have looked through the service manual and other posts on the site and have not found the answer. I am hoping it is a simple 08 or 05 setting that I am missing. Any suggestions would be greatly appreciated.
    Thank you
    Joe
    • 23009
    Re: Missing Paper Size icon
    If you print off the 9S-106 error report do you see C130 or C140 events? Those are paper lift errors, C130 for tray #1 and C140 for tray #2. Usually it's caused by paper behind the paper tray, preventing the paper from lifting properly, but occasionally you'll see a failed lift motor assy. There is no system error reset. Just resolve the problem then power Off/On.
    • Valintine
      • Jan 2012
      • 147
      Thank you for the reply. I am not having a jamming issue. Paper is feeding fine out of the trays. The issue I have is there is no icon to change the paper size in the user function menu. When I ran a factory reset and pressed the user functions button for a brief second I see the icon then it disappears.
      • Valintine
        • Jan 2012
        • 147
        I just realized I listed the wrong model. It is a Toshiba es4540c. Sorry for the mistake
          • 23009
          Did you print the report? C130 and C140 are not paper jams, they are paper lift errors. Model eS4540C does not change the answer. =^..^=
          • Valintine
            • Jan 2012
            • 147
            Yes I did run the s9-106 report and there were not c130 or c140 codes. The machine is running fine and the trays are all set to LT. The issue is that I can not change the paper size for trays 1&2 in the user function menu.
            I was able go get around the issue by turning on the did you change paper size each time they open and close the paper trays. I prefer to leave it off because it avoids wrong size paper jams when users misread the message.
            • Valintine
              • Jan 2012
              • 147
              I found it in an earlier post here on Copytechnet
              Re: Paper size setting for es4540c icon missing
              Originally Posted by mckinley
              It's probably got custom firmware loaded, just upgrade / reload the firmware & it should restore your icon
              To solve the issue, u can upgrade newer firmware, or recover the Drawer icon using code 08-8712 set to "1".
              Thank you very much both Mckinley and Blackcat4866 You have both helped me out now and in the past. I do appreciate the help.
              • Valintine
                • Jan 2012
                • 147
                When I looked back I realized it was didi2005 answer that also helped
