Estudio 3530c
  • pcernicky
    • Feb 2010
    • 66
    [CQ] Estudio 3530c
    Hi guys. I walked to see the copier and this is the issue. Have anyone seen anything like this. The void line is on transfer belt .
    Sent from my SM-G925T using Tapatalk
  • pcernicky
    • Feb 2010
    • 66
    Re: Estudio 3530c
    It's happening only when printing images,doc are ok
      • 23009
      Re: Estudio 3530c
      I've been told that this is a software bug in Windows Picture and Fax Viewer. Try using a different application to open the document. The most versatile application that I know, that will open nearly any file is called "Irfanview": IrfanView - Official Homepage - one of the most popular viewers worldwide
      Does this look familiar?:
      • pcernicky
        • Feb 2010
        • 66
        Re: Estudio 3530c
        No way man,it makes sense now. Will try tomorrow to fix this.
        Thank you very much...
        • Aethanite
          Service Technician
          • Oct 2012
          • 42
          Re: Estudio 3530c
          I hope he fixed the issue because I was about to chime in late and say its most definitely the driver being used. We are seeing this ALOT with customers on Win7/8 machines using the XPS driver (Which is specificity for Windows Vista), where they should be using either PCL or PS.
          • pcernicky
            • Feb 2010
            • 66
            Re: Estudio 3530c
            Yes,that was the issue. Pdf pics and all good.
