5755 takes a LONG time to start printing
  • big mike
    • Sep 2012
    • 155
    [Misc] 5755 takes a LONG time to start printing
    My 5755 was working normal at my account for several. This past week it started to take a LOT longer to print anything. They tried different drivers and I upgraded it to the latest s/w from the Xerox site hoping that would fix it. No such luck. Then I tried printing to it with a crossover. No luck. It still takes a long time, even printing a test print! So it's not the driver, the s/w, their network...has anyone seen this problem?
  • adriansto
    • 2388
    Re: 5755 takes a LONG time to start printing
    Reload machine software.
    • big mike
      • Sep 2012
      • 155
      Thanks, I did reload the software, upgraded to the newest and it still takes a minute or two to print a sheet. They had a 5755 before...it was jamming so it was replaced with another 5755. The previous one printed fine. Any ideas will be appreciated.
      • Exok
        • Jun 2011
        • 750
        Did you try loading the software using the Forced AltBoot method?
        • big mike
          • Sep 2012
          • 155
          Yes, using a usb stick and loading newer s/s, from version ...222 to ...223. It took 20 minutes and printed a config. sheet.
          • adriansto
            • 2388
            What system software was on the previous 5755 ?
            did you tried with the old printer drivers ?
            • big mike
              • Sep 2012
              • 155
              It had 61.132.222... and now has 61.132.223.16190. The customer is printing using the same print drivers loaded from the Xerox website.
              • adriansto
                • 2388
                I asked about software version on the old 5755 who jamming.
                • big mike
                  • Sep 2012
                  • 155
                  The old one had 61.132.221 and is at my shop. Since I brought it back I upgraded the s/w to 61.132.223... and it runs fine for me. They said it was only jamming when 1 person tried to make copies, not printing. I did actually see it jam one time and it was a 8.150 jam (at the reg xport).
                  • adriansto
                    • 2388
                    Ok, try to load the 61.132.221 software version on customer machine.
                    What paper tray is used for copies and what one for printing ?
                    If when print there is no paper jam mean the problem is at one paper tray used for copies.
                    • acfife
                      • May 2012
                      • 63
                      I would try fitting the hard drive from old machine to the new one, have had hdd cause strange issues.
                      • big mike
                        • Sep 2012
                        • 155
                        Good idea, I'll try it.
                        • PJF
                          • Jul 2014
                          • 32
                          is the driver set to LPR or Raw, If its LPR make sure the new machine is spool to HDD.
                          • prismtech
                            • May 2014
                            • 199
                            He's giving you good advice. I've had a stuttering drive cause UI jam up in these machines before.
                            Matched your symptoms...
                            • JrTech
                              • Jun 2013
                              • 217
                              By chance have they upgraded to Windows 10? Having same issues on quite a few machines? On the Xerox 5655 customer upgraded from Windows 7 to 10 and the machine started doing all kinds weird thing like just dropping offline, taking from 1-60 mins for a Scan to Folder and print job, times increases after it starts. PO/PO and the machine worked perfectly fine for a few months, then went to weeks, then to everyday. After updating firmware, reloading software and a little sweet talking, we replaced the IP board and everything is ok.
                              Hope that helps
