Xerox - C45
  • biscopy
    Xerox - C45
    Experienced Xerox Technicians:
    Black copies intermittantly: Run 20 o.k. run 20 n.g
    Good copies from glass
    Black from DADF intermitantly
    Replaced: CCD
    Image Processing Pwb
    Power Dist. Pwb
    Any suggestions
  • TzALbg
    • Dec 2007
    • 111
    C45
    This is usual problem with this mashine
    1. Try to clean all lens and mirrors, check white strip under platten gless.
    2.Premature failure of the Scan Motor Bracket (PL 14.15, Item 18). The black rubber damper can pull away from the metal bracket. Initially the two metal plates start to look non-parallel from one another as the adhesive begins to release.As the machine continues to run eventually the rubber will completely separate from the bracket causing a loss of drive to the Scanner and a 14-110 code.
    Perform a physical inspection and adjustment if necessary
    • biscopy
      C45 - Black copies, grey copies intermittant
      Xerox C45 -
      Not a easy fix
      Whit strip - already cleaned
      Bracket ruber - already checked
      Wiring checked, and in good order
      Illum. Pwb - replaced
      LVPS replaced -
      CCD pwb - replaced
      Needs a software - calibration?
      Anyone familiar with this machine, and or this problem.
