xerox 5775 software
  • sina_vel
    • Feb 2014
    • 33
    [Dead] xerox 5775 software
    hi
    i have xerox 5775 and want to install software on it...
    problem is nvm battery( i install new one ) and now i need software for install
    in the web i found software upgrade for it but it need machine goes to online mode
    my machine stuck in xerox5775 loading page...
    what can i do now?
  • Exok
    • Jun 2011
    • 750
    Re: xerox 5775 software
    1. Get a USB flash drive.
    2. Create a folder on the drive and name it "AltBoot".
    3. Create a text file (.txt) and name it "FORCED_UPGRADE".
    4. Delete the file extension from the FORCED_UPGRADE.txt so that it no longer has the .txt
    5. Place the FORCED_UPGRADE file in the AltBoot folder along with the machine software DLM file.
    6. Power off the copier.
    7. Insert the flash drive into one of the machine's USB ports.
    8. Power the copier on.
    Your machine should now enter software upgrade mode.
    • sina_vel
      • Feb 2014
      • 33
      thx mate...
      but I have done these things, as you say but its not work
      btw i replace nvm battery and machine is comes up
      now i have problem with Network controller
      it stuck in 75% .... then machine power off...
      file name : WorkCentre_5735-5790_system-sw#06113222121403#.dlm
      • adriansto
        • 2387
        It is a good idee to use 57xx pws tool and using altboot to see the boot process of sbc board.
        In this way you will see if the sbc board sense the usb stick you use to reload software.
        If not, you need nvm save and restore tool from pws tool to reload machine nvm's and after that to do software reload. Or you can do altboot from pws tool
        I hope the battery you changed is the yellow one no the round one from mcu.
