Good working machine some time show error massege print engine fault.
Xerox 440 dc print engine faulty
Look at the fault history and write the latest faults because print engine fault could be a lot of things.! RTFM !
My site: http://www.e-club.gr/ -
This failure is the main engine. Remove the engine, dismount that the mobile part of it, you'll do three parrafusos that the coil, they should be loose and just squeeze you solve your problem.Comment
