Should plastic gears be lubricated in a copier?
  • Joel_M
    • Jan 2017
    • 24
    I'm wondering if the plastic gears in the DC12 I'm servicing should be lubricated with oil or light grease - they look like they could use it, but I know that there could be issues with dirt attraction and reaction with the plastic. Should they run dry or if not, what is recommended?
  • jose antonio
    • Dec 2012
    • 119
    Re: Should plastic gears be lubricated in a copier?
    Yes they should, there are different types greases for plastic gears. Most are white like brill cream hair dressing.
    I used to use one called plastic-slip grease.
    Jose Antonio
    • copyman
      Owner / Technician
      • Sep 2005
      • 4742
      Most "nylon" (plastic) gears don't need to be lubricated but if necessary make sure grease is meant for plastic. Some grease can deteriorate plastic.
