Blank Copy - Xerox M15i
  • copyman111
    I have blank copies on a
    Xerox M15i.
    The customer said the copy
    quality was increasingly lighter
    and lighter, now blank.
    I exchanged the cartridges
    with known good cartridges.
    I exchanged the transfer
    corotron with a known good
    corotron.
    I removed the low voltage
    power supply and put in a
    another machine and it works
    fine.
    I'm not aware of where the
    high voltage ps is located.
    I have no documentation.
  • service.one
    M15i Blank Copies
    Pull the back cover and check the ribbon cable that goes to the scanner/CCD, if it comes loose, it will give blank copies. Also, if it was gradual, it may be a dirty scanner mirror(s) there are 5 or a lens issue either on the scanner or the ROS (laser)
    Hope this helps, Good Luck.
    • hana_freak
      • Oct 2008
      • 44
      Hi,
      Only copies from the platten or ADF show the fail?
      Internal prints ou sent by PC are ok?
      Antonio
      PS. the hight voltage PS is in same PWB in the lower voltage PS.
