DCP 770 with 042-327...
  • Toner Boy
    • Aug 2007
    • 366
    Started with 42-326. Cleaned patch sensor, cleaned belt underside (teflon cover over patch coming off), reset 741-105 to 0 (swear it was like 126 prior to reset?). Failed. Cleaned belt edge sensor, and reset 741-106 from 3 to 0. worked...briefly, then constant failure.
    Purchased new IBT and cleaner assembly, installed, belt edge learn...worked for about 60 pages, barfed up 42-327. This will not clear, belt edge learn fails. Have re-centered belt like 15 times, fails -CREEPING TOWARDS FRONT OF MACHINE.
    Watching (and listening) to belt steering motor/cam gear shows gear running counterclockwise and stalling out when it hits cam end notch. Shouldn't it be running clockwise during initialization (closing front door sw)?. Going back tomorrow with sledgehammer, will try belt edge sensor from DCP 700 (unknown condition).
  • Toner Boy
    • Aug 2007
    • 366
    Re: DCP 770 with 042-327...
    UPDATE. ITB assembly works perfectly in another machine (700).
    But I've got no idea where to go from here. Connectors, wiring, PWB...
    • InterfaceP
      • Jun 2013
      • 488
      MCU is probably bad.. It's different than a 700 so don't try to swap them out.
      As an option you can send it to me to test. I'm located in Dallas TX. PM me
      • adriansto
        • 2387
        Save registration nvm's then initialise iot nvm's only.
        If after that is same situation change the iot driver pwb.
