Start working on Xerox in a week...
  • kev577
    • May 2016
    • 12
    Any recommendations for a Sharp tech with 13 years experience to start working on Xerox? I've never even made a copy on one.
  • alliedofficeproducts
    • Jan 2015
    • 92
    Re: Start working on Xerox in a week...
    If it was me I'd run. Xerox has some bad mojo.
    Sent from my LGL41C using Tapatalk
    • rockdude
      • Feb 2011
      • 257
      It really depends what machines you will be working on?
      If you are just working on the small to lower end stuff, your Sharp experience will get you thru most repairs.
      If you are going to be working on mid-size to upper end machines, I hope you are going to work for a Xerox dealer. (or at least have a Xerox trained tech working with you)
      As you will need to contact escalated tech support sooner or later, and they only talk to techs that.
      A: Are certified trained on that product.
      B: Work for a authorized dealer ASP.
      This forum is probably one of your best bets if you don't have either of the above.
      (Also you will have to get used to Xerox edoc's manual system)
      Good luck
        • 8202
        I share your pain.................
        โ€‹
        • kev577
          • May 2016
          • 12
          Good luck
          Luckily we believe in training, Xerox coming for 7 weeks to train us, then I'm the TTT trainer. We will be working on everything from desk tops to "graphic color". I hope the hotline is better than Sharp's.
            don't walk away
            RUN AS FAST AS YOU CAN!
            • Milo Wilson
              • 508
              What's the biggest model you'll be allowed to service?
              • prismtech
                • May 2014
                • 199
                All the new Xerox machines are cheap Chine garbage.
                Get used to pulling out little broken nylon gears.
                  xerox has been using Samsung engines in their boxes for a few years... no wonder they are sooo crappy.
