DC260 developer
  • big mike
    • Sep 2012
    • 155
    DC260 developer
    Has anyone ever used DC5000 developer in a DC260 developer housing? The package weight is identical, etc. Any help is appreciated.
  • msoundpr
    • Mar 2011
    • 15
    Re: DC260 developer
    Hi, Do not use DC5000 developer on a DC260, the DC5000 use toner with oil, the fusing of the DC5000 is base on a oil system, the DC240,42, 250, 252, 260, family is the same.
    • davidj7
      • 1107
      Re: DC260 developer
      If you planning to used a DC260 developer assy on a DC5000. Go ahead it would run just fine.
      a machine is only as good as your tech : source:screwtape ; the scary one
      • Caffeine
        • 391
        Re: DC260 developer
        The hardware (the housing itself) from either machine can be used in either machine, but DO NOT use DC5000 developers in the 260. It won't work even a little bit.
        • big mike
          • Sep 2012
          • 155
          Re: DC260 developer
          Thanks, I won't use it.
