Hi All.
I had to replace the magenta dev unit after the seal failed and blocked the dev unit ever since then I have been getting spots of magenta drop down scattered across the page - I thought this might have been due to a build up of dev/toner from the split seal but after running over 500 pages through its still there. I have cleaned all the surfaces that I can see and pulled the transfer belt out and cleaned up and under.
Does any one know if this will pass with more copies passed or am I missing something obvious?
Chris
Chris
