7970 with yellow
  • big mike
    • Sep 2012
    • 155
    [CQ] 7970 with yellow
    I got a 7970 to refurb and sell. It is a new product family for me. The prints are excellent and everything works. The issue is when you make copies.
    A color doc has a solid yellow background and the b/w mode makes a grey bkgnd. I cleaned the optics and did the IIT adjustment, it passed all three steps. No change. I did it again, reset NVM for scanner and copier, still does it. I looked through the pws. When I scan to public folder it has the yellow background. Could it be the CCD? Any ideas will help...
  • adriansto
    • 2392
    Re: 7970 with yellow
    White strip under the glass ?
    • Richard.Xerox
      • Jun 2015
      • 73
      is it on side 1 or 2 or both? This machine has a side 2 scan assembly so important to isolate which side it is.
      write 1 and 2 on opposite sides of a piece of paper and insert into the DADF with the 1 facing up, copying this 1=CVT strip and 2=side 2 assembly
      if side 2 is yellow background - Pull out the SBC drawer and reseat the Pyxis PWB attached to the back.
      If it's only side 1 it could be faulty IIT PWB.
      If both sides yellow background it's likely to be the SBC PWB or one of the memory modules.
      So to sum up:
      Side 1 = IIT PWB
      Side 2 = Pyxis PWB (or rarely the side 2 scan assembly)
      Both sides = SBC PWB or Memory DIMMs
