Xerox Dc 250/252
  • DheerajBE
    • Feb 2018
    • 39
    [CQ] Xerox Dc 250/252
    Dear All,
    I have Xerox Dc 250 machines it has a problem of color registration out.
    when I start registration control setup from the maintenance and diagnostics it shows me most of value are NG.
    I have done below diagnostics to solve this error but all failed.
    1. tried changing registration sensor assembly (3 different sensors).
    2. Initializing NVM value.
    3. Re-write all original machines NVM value.
    4. swapped drums and developer units from other working machine.
    Please help.
    www.viagrasansordonnancefr.com viagra france ordonnance
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox Dc 250/252
    Clean ros
    • DheerajBE
      • Feb 2018
      • 39
      Originally posted by xcopytech
      Clean ros
      I forgot to mention but ros are clean
      • adriansto
        • 2387
        Nice, but what about IBT assy ?
          Dear All,
          Please help.
          what error codes are showing in the error list?
          • SeniorTch
            • Jun 2017
            • 117
            try this: remove the left cover, conect tray 5, Run DC675 setup, check the marks on belt Chevrons and parallelograms shape (yellow_black marks)if one of them is NG.check for drums, developer, cleaner blade etc. Ckeck inboard, center and outboard marks.
            • Detonation
              • Feb 2010
              • 410
              What about MOB ADC assy?
              • DheerajBE
                • Feb 2018
                • 39
                Thank you all,
                It was due to bad drums and developer assembly.
                I had to change drums and adjust toner density in developer unit and run registration setup unless it comes to OK
