xerox 8870 printhead
Re: xerox 8870 printhead
Yes you have screwed the pooch! Good job!Comment
As result the BK M C and Y reservoirs not filled.
There are a long list of checkings need to be done for managed this error.
So , if you want to continue, get service manual and follow the proper procedures described there.Comment
You've killed the printhead.
Not sure where you are, I should have some print heads available still. But I'm based in Europe, so better buy on eBay if you live outside of Europe.Comment
Hello
Today we changed the Purge Pressure Pump and the printer showed no error. We broke that little plastic while trying to remove the printhead. We 'baked'
the printhead 2 times , it didn't get damaged but it didn't fix the missing jets issue either . We will buy a used printhead from ebay and hopefully will sort
all our problems.Comment
Nematullah
