Xerox WorkCentre 7835 does not exit energy saver mode
  • Detonation
    • Feb 2010
    • 404
    Machine is on 073.010.068.33100 software that was clean installed using altboot. All machine functions work fine, but when it enters energy saver mode, it is unable to exit it. Pressing the green button either doesn't do anything or causes the machine to reboot.
    I've changed SBC, LVPS and LVPS fan (since it isn't spinning - it isn't now either even though I have replaced both LVPS and fan), and also the hard drive.
  • MrXerox
    • Sep 2010
    • 76
    Re: Xerox WorkCentre 7835 does not exit energy saver mode
    • Detonation
      • Feb 2010
      • 404
      • Detonation
        • Feb 2010
        • 404
        Bump, since I haven't been able to figure out the problem just yet...
        • Richard.Xerox
          • Jun 2015
          • 73
          Sounds like loss of +5VDC standby power which is normally cured by replacing the LVPS which you have already done.
          I'd order up another LVPS and before replacing it troubleshoot for shorts in +5VDC standby power, something is pulling it down. Could possibly be worth replacing the UI assembly also.
          • Detonation
            • Feb 2010
            • 404
            Thanks Richard will try this Monday.
            • Detonation
              • Feb 2010
              • 404
              Replaced the LVPS with a known good one and the UI assy as well, but no luck. Will search for shorts in the 5V circuit.
              • Richard.Xerox
                • Jun 2015
                • 73
                Anything of note pop up in the fault history once you power device back on after this fault occurs?
