slow @ start prntingi
  • big mike
    • Sep 2012
    • 155
    [Misc] slow @ start prntingi
    When I send any document to my 5955's it takes 40 seconds before it feeds paper. When I send it to my 5775 or 7970 it takes 5 seconds. The software is the newest version.
    My customers find it annoying. Any ideas?
    Re: slow @ start prntingi
    what are the settings on the slow unit?
    are all supplies/parts low in life count?
    how are the printing to each unit?
    are there any errors listed in the log?
    you give us little to work with!
    PhilB "The Dentist"
      • 30567
      Check they have the correct print driver and not a WSD port and driver.
      • big mike
        • Sep 2012
        • 155
        PhilB "The Dentist"
        I am using a pcl6 driver, and I tried the MS Certified driver.
        The supplies are almost new.
        No errors listed related to printing, it had a couple misfeeds from tray 3.
          • 23010
          Is your slower machine set to Heavy media type? =^..^=
          • big mike
            • Sep 2012
            • 155
            I added a tcp/ip port, not using the WSD. The driver is PCL6, and I used the MS certified driver.
            On the older machines the 58xx series, I noticed some software versions tend to take longer before it starts to print. I find the "i" series are bloated with apps that slow it down.
            • big mike
              • Sep 2012
              • 155
              No, the default paper, 20#
              • howling
                • Feb 2019
                • 35
                try putting it in port 9100
                • big mike
                  • Sep 2012
                  • 155
                  I will try it and see what happens.
