Xerox Color 550 DC250 Soft deletion on Black only
  • calpika
    • Mar 2019
    • 6
    Hoping someone can offer a suggestion for this problem. I have a white band that runs on black only down the page.
    Here are the things i've tried:
    -Replaced developer/developer housing
    -Replaced black drum/charge corotron
    -Cleaned ROS (easy method by going from under with a clean cloth -added contaminants but line did not improve)
    -Replaced belt
    -Recently replaced 2nd BTR
    Sort of running out of options at this point....
  • Detonation
    • Feb 2010
    • 410
    Re: Xerox Color 550 DC250 Soft deletion on Black only
    The 1st BTR might cause it, but I doubt it. More likely you need to clean the ROS from the inside.
    • calpika
      • Mar 2019
      • 6
      Will try to clean ROS, i tried replacing the entire belt assembly with one from another machine and did not work.
      Thank you
        are these prints or copies?
        • calpika
          • Mar 2019
          • 6
          The pictures are from copies, but it has them on prints too
          • calpika
            • Mar 2019
            • 6
            Cleaning the ROS window fixed the issue.... I cleaned inside where the laser unit was, but i don't think it was necessary.
            • Detonation
              • Feb 2010
              • 410
              Since you mentioned you already cleaned the ROS window I figured contamination could only be on the inside. Glad you fixed it though! Cleaned the ROS from the inside is such a pain...
              • xrxdheeraj
                • Sep 2017
                • 23
                -Replaced belt
                [ATTACH=CONFIG]44498[/ATTACH]
                from above images i doubt CK ross or black developer unit. try changing ross
                • zagrex
                  • Dec 2011
                  • 63
                  Hi you are have problem developer housing
                  check dev.hsg (between the blade and the roller)
                    Me thinks you didn't read ALL posts before you made yours.
                    calpika
                    Junior Member Join DateMar 2019LocationPasadenaPosts4Post Thanks / Like
                    Rep Power0
                    • calpika
                      • Mar 2019
                      • 6
                      I figured that cleaning the window from below would suffice, and noticed that it made no change at all on the line.
                      But after taking it appart, noticed that trying to wipe the window from under the unit is virtually useless... at least in this case.
                      Hopefully someone aside from me learns from this. Sometimes it's not enough to try and quick clean the ROS window.
                      • knightfall
                        • Jul 2006
                        • 633
                        Thank you
                        the ROS is the laser unit the shield you cleaned is not the side that is dirty it might be the other side of the glass shield, so take the laser out and clean the other side of the laser shield.
                        Get your facts first, and then you can distort them as much as you please.
                        • xrxdheeraj
                          • Sep 2017
                          • 23
                          calpika
                          Rep Power0
                          I told you already.
                          • nikolai.aleksie
                            • Feb 2016
                            • 177
                            Xerox Color 560 Soft deletion on Black only
                            Hello,
                            What could cause damage to the Charge Corotron in the Xerox Color 560, leading to the appearance of such defects (attached images)?
                            I understand that damaging the Charge Corotron is almost random.
                            The first thing I did was clean the ROS window, changed the Developer due to defective gears, then switched the Drums with one from another Color 560 and found that the problem moved with the Drum. I suspected it might be a faulty Drum, even though it still had about 30% life left. I replaced it, and the print was perfect again, but not for long. After about 10K copies, the traces began to reappear. Then I decided to only replace the Charge Corotron, and everything was fine again.
                            I tried cleaning the Charge Corotron with isopropyl alcohol, but it didn't work; it actually got worse.
                            Please provide guidance on what could cause this type of Charge Corotron damage.
                            P.S.: All consumables are original.
                            Thanks in advance
                            • xcopytech
                              • Aug 2006
                              • 1794
                              Why you have not start your own topic?
                              Replace filters on machine for longer corotron life
