Xerox series 56xx fuser
  • Enzo
    • Jul 2009
    • 413
    Hello my friends. I have several xerox 5645/245 series machines which use the fuser 109r00751 and drum 113r00672. For the drum I can also use the 113r00608 without problems (obviously changing the chip). Can I use another one similar to 109r00751 for the fuser? Or can I extrapolate some parts from other fusers? thanks a lot
  • GIUBOSS
    • 1436
    Re: Xerox series 56xx fuser
    For internal spare parts, if the assembly is very similar, I think so (specific chip). However, it is better to check the supplier tables with the compatibility of the consumables.
    • xcopytech
      • Aug 2006
      • 1794
      113R672 and 113R608 do not have same charge corotron, so I am not sure that you can use 113R608 in faster machines. (5655, 5665, 5755 etc)
      For fusers just change chip.
      • Enzo
        • Jul 2009
        • 413
        Hello Friend. I use 113r00608 (with 113r00672 chip) together with corotron and I have never had problems. In your opinion, what other fuser can I use that is perfectly compatible with 109r00751?
