Xerox wc7855 (error 310-330-00)
  • omorales
    • Mar 2015
    • 86
    Hello friends, I wanted to know if someone had this error, 310-330. The motor of the fusion unit was changed, but it remains the same.
    Re: Xerox wc7855 (error 310-330-00)
    Thanks for the help[ATTACH=CONFIG]46378[/ATTACH]
    is the fuser binding also?
    what did the customer say happened before the error popped?
    I can't open your attachment
    looking through the SM I don't see that error code .. please check n verify
    • Detonation
      • Feb 2010
      • 403
      310-330 is a fuser motor fault. Have you tried activating the motor from component control? If the motor is fine, but it is not activating, the MDM PWB is most likely the problem.
      • savi0r
        • Sep 2010
        • 363
        Hello. Your problem is the fuser. I had this error recently myself. It doesn't rotate smoothly and thus the error. Change the fuser and you'll see the problem is solved. Maybe lubricating the heating element will do it, i know there's a special oil for it. But i didn't tried it.
