PWS Searchlite pane is blank
  • JR2ALTA
    • Feb 2010
    • 2033
    Does anyone know what causes or what fixes this? I have tried a Windows system restore and the PWS repair utility. The only thing I may have done is run a BUS update with IE open. I am new to Xerox.
    Thanks in advance.
  • dio
    • Apr 2015
    • 10
    Re: PWS Searchlite pane is blank
    Did you ever find a solution to this?
    • kollega_pro
      • Sep 2021
      • 6
      PWS Searchlite does not work on windows 10.
      the last time I saw how it worked correctly, it was on windows XP 32 bit
      • ThisPete
        Too old to care
        • Jun 2014
        • 202
        It works fine on both my Windows 10 laptops..
        • Rusty.Harris
          • Jan 2021
          • 629
          Everytime it stops working for me, it's typically after a windows update. If you don't have it, search for the release 12.x utility.
          Anytime PWS goes bonkers, I run that, and it restores it to working.
          HOPEFULLY Xerox will release a new software that works well with 10 & 11, since IE won't work, per se on 11.
          You can run it in IE compatibility mode, but they really need to update that software & the edocs.
          • JR2ALTA
            • Feb 2010
            • 2033
            I think the you mean the "repair" utility. That usually does fix things but didn't fix my searchlite issue. My company's IT dept reloaded all the PWS software to fix it.
            Sorry to those looking for an update, I didn't realize.
