Strange Print Marks with 7845 7970 STYLE MACHINES
  • drewzif
    • 101
    See image for better understanding. This page is from the print quality test.
    I notice this issue usually after changing a transfer belt.
    The strange marks do not appear to be repeating.
    • 16374
    Re: Strange Print Marks with 7845 7970 STYLE MACHINES
    Originally posted by drewzif
    [ATTACH=CONFIG]47205[/ATTACH]
    The picture isn't big enough for me to see anything but if the marks are repetitive, did you measure the distance between? And what is the measurement?
    Edit: Sorry, I misread. I thought you said the marks are repetitive. Please disregard.
    • drewzif
      • 101
      Sorry, told it to post full size.
      Please click this link to see image.
      black-spots-7845 — ImgBB
      The pattern does not appear to be repeating at all.
      • Detonation
        • Feb 2010
        • 410
        I've seen that and it's to the ITB unit. Do you change the entire unit or just the belt?
          IMHO to change JUST the belt and not to clean the rollers is a waste of time... toner/paper dust can get under the belt and collect on the rollers causing PQ/CQ issues.
          also I hope he cleaned/changed the cleaner assmy
          • thomfish
            • Jul 2014
            • 101
            Have you checked if metal roollers under ITB Belt are not scratched? I have seen similar problem on 71xx and found scratched roller (probably someone tried clean it but damaged it instead).
            • Detonation
              • Feb 2010
              • 410
