blacks are coming very thick and not sticking to paper properly,
  • Shahn
    • Aug 2017
    • 30
    Xerox dc 252, blacks are coming very thick and not sticking with paper properly, text also comes thick, look at poster top right corner , using original toner and dev unit, please help !!
  • Gaffers01
    • May 2011
    • 335
    Re: blacks are coming very thick and not sticking to paper properly,
    What thickness of paper are you using?
    What type of paper is it?
    • Sn0wlink
      On-Site Engineer
      • 35
      I'm not familiar with this model but:
      If it's running on coated stocks, sometimes you get issue with toner transfer voltage. See if there are any adjustments that can be made to these settings.
      It maybe a possible fuser problem (unlikely) try reseating the connector on the fuser unit.
      Hope this helps.
      There's the tool the works, Then there's the tool that is Right!
      https://www.sn0wlink.com
        • 23009
        This is definitely a fusing issue. Either your media type is not set correctly or the fuser is not maintaining temperature. You'll see this especially in areas of color that have over 50% of each color or 200+% fill. It takes a lot of heat to fuse those heavy fill solids.
        So, first:
        Is the media glossy?
        What media weight are you using (in gsm)?
        What media type have you selected for the tray feeding the paper?
        How many images on that fuser?
        • Shahn
          • Aug 2017
          • 30
          its 100gsm copy paper, I have selected plain paper on machine, if I set heavyweight, print comes darker( like more black ).
            • 23009
            I don't really work on Xerox, so you'll need to consult you own users menu to determine the proper media type. I'm thinking it will be Thick1.
            And you didn't notice that it fused properly with Thick1? Changing the fusing temperature is not the way to address color issues.
            • allan
              RTFM!!
              • 5462
              And its all good on 80gsm? Can you rub the toner of using a finger or does it stick well to the paper?
              Paper going in nice and dry or damp?
              Like BC said could be as simple as fusing transport speed.
              Whatever
              • adriansto
                • 2388
                You must done the dC991 - tone up/down but I recomand you all MaxSetup procedures or at least, dC950, 924, 991.
