NOTICE: Users should expect a few periods of downtime this evening while we work on a few updates to the system.
blacks are coming very thick and not sticking to paper properly,
Xerox dc 252, blacks are coming very thick and not sticking with paper properly, text also comes thick, look at poster top right corner , using original toner and dev unit, please help !!
Re: blacks are coming very thick and not sticking to paper properly,
I'm not familiar with this model but:
If it's running on coated stocks, sometimes you get issue with toner transfer voltage. See if there are any adjustments that can be made to these settings.
It maybe a possible fuser problem (unlikely) try reseating the connector on the fuser unit.
Hope this helps.
This is definitely a fusing issue. Either your media type is not set correctly or the fuser is not maintaining temperature. You'll see this especially in areas of color that have over 50% of each color or 200+% fill. It takes a lot of heat to fuse those heavy fill solids.
So, first:
Is the media glossy?
What media weight are you using (in gsm)?
What media type have you selected for the tray feeding the paper?
How many images on that fuser?
I don't really work on Xerox, so you'll need to consult you own users menu to determine the proper media type. I'm thinking it will be Thick1.
And you didn't notice that it fused properly with Thick1? Changing the fusing temperature is not the way to address color issues.
