Xerox 7120 error 062-311 when scan store to folder only on Use the document glass
  • nochick
    • Jan 2012
    • 80
    [Error Code] Xerox 7120 error 062-311 when scan store to folder only on Use the document glass
    Xerox c7120 / IV c2260 error code 062-311 when scan "store to folder" only on Use the document glass.
    but if use document feeder it's ok
    Copy and Print is alright.
    change HDD result is the same
    What can i do next?
  • GIUBOSS
    • 1435
    Re: Xerox 7120 error 062-311 when scan store to folder only on Use the document glass
    the error could be caused by the flat cable of the scanner damaged, if possible also update the firmware
    • nochick
      • Jan 2012
      • 80
      3 Days Ago
      GIUBOSS , thank you very much.
