C9070 print quality
  • Rusty.Harris
    • Jan 2021
    • 633
    C9070 print quality
    My I.T. guy just showed me some samples, poor print quality on a 9070
    One printed on a Mac, other printed on a PC. BOTH exhibit the same issue.
    Form created in illustrator. The prefilled part of the form, the letters have the
    "toner blast" effect around the edges of the letters. But, the parts of the form
    where they filled in the blanks, the fonts look perfect.
    When the exact same form was saved as a PDF, issue is the same. I brought
    the pdf into photoshop because I don't have illustrator and it looks like the form
    isn't "flattened" (at least when I work on a photo in photoshop, it looks like it isn't
    flattened). Now, when they print to a different machine, non xerox, EVERYTHING
    looks perfect.
    Everything else on the 9070 looks ok according to the tech. This is an almost
    brand new machine too.
    Any suggestions?
    Dropbox - DOC033021-03302021160824.tif - Simplify your life
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: C9070 print quality
    Are you a Xerox company or new to them?
    In case your new: Nothing is more important on these than the correct paper profile. You really shouldn't use any of the default paper types you need to create your own paper catalog for each stock the customer has. Each with their own transfer and fusing properties.
    • Rusty.Harris
      • Jan 2021
      • 633
      Well, the strange thing that our I.T. guy said was that it printed funny on the Xerox, but the same file, on another
      brand machine, printed perfectly. I'll ask him on Wednesday if it was like this from the beginning, or, just started.
      Tnx.
      P.S. Only been a xerox "dealer" for a year.
      • Rusty.Harris
        • Jan 2021
        • 633
        OK, try this...
        Tech went back out. I wanted him to verify the file was flattened. It was. He had the file on his thumb drive,
        and put it in the usb port on the 9070. He said the print job from the usb port looked PERFECT.
        I know on other manufacturers (I deal with Toshiba mostly), I've had bad memory cards cause CQ issues.
        If you are more familiar with Xerox, could this be a bad memory card on the machine?
        He then took the file on his thumb drive, that printed correctly from the usb port, and put it in a Mac
        and printed that file on his thumb drive, from the Mac. The letters were again fuzzy.
        Took the thumb drive, plugged it back into the 9070, and printed it from the 9070 usb port, and it
        looked perfect again.
