Xerox C60 Jams at Fuser Exit & Error Code 077-103
  • marcodm
    • Jul 2023
    • 3
    #16
    Re: Xerox C60 Jams at Fuser Exit & Error Code 077-103
    Originally posted by adriansto
    There are multiple reasons for this error:
    decurler assy ( motor ), exit assy drive motor or clutch, fuser exit sensor, dry white plastidip on gears and so on. You must look what others error appear in machine faults history.
    thanks I will check
    • Detonation
      • Feb 2010
      • 410
      #17
      It also helps to check if the problem only occurs when printing (single sided) with printed size down (default), or also with printed side up.
      • Kwaku Abrokwah
        • Nov 2024
        • 4
        #18
        Hello, please anyone fixed this issue yet? I'm getting the same issue of paper jamming but only on A4 size on Xerox J75 Press. I'm getting these error codes: 077-103, 077-111, 048-100
