Anyone get edocs to work with MS Edge?
  • Rusty.Harris
    • Jan 2021
    • 629
    I can get the "home" page of gsn to come up, by going to
    /XEROX/XPWS/DATA/HOME/home.htm and obviously get to the GSN "start"
    page.
    I'm guessing because everything is in java, is why you can't get any of the edocs to open?
    October, when Win11 is "suppose" to be released will be here soon enough. I installed it
    on a VM and if you search for internet explorer, it is NOT found because they don't support
    it and removed it. I'm trying to get ahead of the curve because Xerox hasn't said anything
    that I've heard, about win11/edocs etc.
  • jhalfhide
    • Apr 2015
    • 454
    Re: Anyone get edocs to work with MS Edge?
    My guess would be that because you can't navigate using the proper plugins, there's also no GSN Lock check ability so you really won't be able to view anything.
    Their best bet if they want speed and to retain a similar working method and control, would be a chrome plugin. They created a chrome plugin for the app gallery installer.
    They may be able to get a Chrome plugin working with GSN Lock, and basically just switch browser.
    Sent from my LYA-L09 using Tapatalk
    • fugglefeet
      • Jun 2020
      • 34
      Hi all,
      The sad news is that the GSN and PWS software was all written around IE. With the support for IE stopping in the foreseeable/near future, the development team have got a monumental task ahead to do a complete rewrite from the ground up of the electronic documentation.
      fugglefeet.
      • Dech
        • Aug 2014
        • 48
        Just loaded windows 11
        Just run it in I.E mode in edge..( default browser) set up a xml file with all the i.e roots, add it to group policy then share with i.e
        Add the roots to the docs, so that it opens in i.e mode.
        Mine works with everything, except bus-station
        If anyone knows the full root to
        Psw://file/*|
        Psw://busrec/*|
        Its ok, I just gave myself the root..lol forgot the | on the end..
        • ThisPete
          Too old to care
          • Jun 2014
          • 202
          Psw://file/*|
          Psw://busrec/*|
          Hi Dech, could you explain that all in a bit more detail please.
          • PROCOPY10
            May God bless you
            • Jun 2021
            • 2
            Psw://file/*|
            Psw://busrec/*|
            Sir hello
            Can you please help us
            Please tell us the whole procedure how to install and Fix in windows 11
            Because in windows 10 everything is finished (Adobe flash player removed etc)
            So i only want to view Edocs only
            • Rusty.Harris
              • Jan 2021
              • 629
              Read this on a tech blog
              Microsoft reminds us that Internet Explorer is being killed off on June 15 | TechSpot
              Killed off in June of 2022, then, shortly after, an update will actually REMOVE IE from your computer.
              • jhalfhide
                • Apr 2015
                • 454
                Re: Read this on a tech blog
                Haven't heard a peep from Xerox about this new platform being released before that date.
