Xerox C60 ESS replacement
  • copytechman
    • Nov 2008
    • 939
    Good day everyone , we have a c60 that was subject to multiple power flickers during a storm which ultimately took out the ac ps, the mcu board and the smaller io board behind the controller chassis, the ess is due to be replaced but upon replacement all we get is a white screen, the edoc doesnt mention anything but doing firmware and moving the old bits to the new one, there was no sd card chassis or card on either the old or new ess board. the clock is damaged on the old ess board and the device refuses to make a colour copy and jams at registration but will print black and white with the same paper all day long. (this behavior only started after the power event).
    Is there something special regarding installing firmware via USB that im missing after doing the ess? holding down power save while turning it on doesnt do anything (just constant white screen) where it goes into download mode on the original ESS board. Any input would be appreciated. The device just boots to white screen regardless of holding the energy saver button or not.
    Thanks..
    A.
  • xcopytech
    • Aug 2006
    • 1794
    For color print jam change nvm 742-180 to 1.
    If you change ESS pwb, then remove sd card from old pwb to new.
    • copytechman
      • Nov 2008
      • 939
      There is no sd card on either ess pwb tho but I am willing to check that out , what does that nvm setting represent? Ty!
      A.
      • xcopytech
        • Aug 2006
        • 1794
        Nvm disable ohp sensor, and c60 must have sd card
        • copytechman
          • Nov 2008
          • 939
          • xcopytech
            • Aug 2006
            • 1794
            White screen, missing sd card
            • copytechman
              • Nov 2008
              • 939
              • adriansto
                • 2387
                The code for printer is QGQ and run on 110 volts?
                What is the ess pwb partnumber? May be it is for X560 machine.
                • xcopytech
                  • Aug 2006
                  • 1794
                  If your machine is C60 then it must have sd card.
                  • Dech1
                    Senior Engineer
                    • Dec 2022
                    • 61
                    SD card found here
                    • copytechman
                      • Nov 2008
                      • 939
                      • copytechman
                        • Nov 2008
                        • 939
                        Originally posted by Dech1
                        SD card found here
                        • adriansto
                          • 2387
                          In January 2021 XEROX has launched factory new produced EC70 printer. Code QGQ and 110 volts only. Also only for North America and Latin America market place. May be you deal with this machine. No other information about this. What are the partnumbers of your ess boards?
                          • Caffeine
                            • 391
                            No version of the C60/C70 uses an SD card, at least not in NASG.
                            • adriansto
                              • 2387
                              This printscreen is from edoc PTO. Also in edoc are 3 partnumbers for ESS pwb. Edoc is updated until december 2020 in PWS software.
                              I dont know in Prolibro if it is some update about this. ScreenHunter_87 Jun. 15 16.55.jpg
