Fuser system error
  • Reeves
    • Apr 2012
    • 296
    [Error Code] Fuser system error
    I have the xerox wc7855 displaying fuser system error sometimes it ll work okey then it brings the fuser system error the fuser unit has life before it finishes what could be causing this
  • shinchan
    • May 2011
    • 197
    whats is the error code?
    a lot of causes:
    1. fuser motor
    2. fuser film compatible quality... mostly happens in higher speed machine.
    3. thermostat
    • BernadineCollins
      • Dec 2024
      • 2
      The error can be caused by dirty or worn parts, temperature sensor error, firmware problem, electrical,... to be sure and fix it immediately, I think you should take it to a repair shop to have a more realistic and objective view.
      • Detonation
        • Feb 2010
        • 410
        Have you already replaced the fuser, but does the problem keep coming back?
        • Jack79
          • Jul 2014
          • 312
          What is error code? From memory If it is 310-330 then replacing fuser should solve the problem.
