I have the xerox wc7855 displaying fuser system error sometimes it ll work okey then it brings the fuser system error the fuser unit has life before it finishes what could be causing this
Fuser system error
Tags: None
a lot of causes:
1. fuser motor
2. fuser film compatible quality... mostly happens in higher speed machine.
3. thermostat
The error can be caused by dirty or worn parts, temperature sensor error, firmware problem, electrical,... to be sure and fix it immediately, I think you should take it to a repair shop to have a more realistic and objective view.Comment
