weird cyan yellow magenta pattern FX Docucentre v C5575 / altalink C8055 / WC 7955
  • shinchan
    • May 2011
    • 195
    I have a machine, machine model is fuji xerox Docucentre V C5575 , equivalent of xerox altalink C8055 or xerox workcentre 7955 (sorry if I am wrong).
    customer states that this problem is intermittent. sometimes there are weird yellow, cyan, and magenta pattern during printing.
    things I have done to try solve the problem
    1. replace drum unit, cyan, magenta, yellow.
    2. replace developer cyan, magenta, and yellow (check the seals and housing, everything is good)
    3. Check the transfer belt, it's clean outside and inside.
    machine uses original toner, developer, and drum.
    anybody got suggestion?
  • Detonation
    • Feb 2010
    • 404
    I would take out the ITB assy and take off the ITB to see how the BUR and 1st BTR's are looking.
    • Dech1
      Senior Engineer
      • Dec 2022
      • 61
      2nd btr roller. Open left side door, the sponge roller in the door
      • chelsaoe
        • Mar 2019
        • 8
        itb body clean
        • shinchan
          • May 2011
          • 195
          What I have done so far:
          1. Replace BTR unit.
          2. Replace IBT unit.
          3. Replace the board / power supply for BTR and IBT.
          and still the mark is there. Not always, but sometimes...
          Tomorrow I will replace the whole machine. Bring back to workshop and try troubleshoot.
          • TECHVIN
            • Nov 2021
            • 3
            I Would suggest you to check drum unit charger for missing earthing.
            2ndly, check and clean ibt or change it.
            Rare case, it could be drum driver motor.
            check and change hvt boards and 2nd btr as your last resort.
            • Jettdog
              • May 2021
              • 48
              Is there a cleaning unit on this model?
              • Detonation
                • Feb 2010
                • 404
                Come to think of it, I've had a similar issue with a DocuColor back in the day. The cause for that particular machine was a flaky connection to the 2nd BTR. Might be worth checking th left had door to see if the connection to the transfer roller / 2nd BTR is still good and hasn't bent out of shape.
