Fiery stuck at FF
  • Reeves
    • Apr 2012
    • 296
    [Error Code] Fiery stuck at FF
    Hi am reloading system software on the fiery using usb its now 1hr it's stuck at FF is it still loading or it has finished coz it has to display 00
  • PrintWhisperer
    • Feb 2018
    • 470
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • Reeves
      • Apr 2012
      • 296
      Re: Fiery stuck at FF
      Thanks for the respond
      • adriansto
        • 2387
        What machine ?
        • Reeves
          • Apr 2012
          • 296
          I formatted the HDD reload system software still it was stuck at FF I connected the HDD to the pc there was nothing in the HDD just 500GB
          • Reeves
            • Apr 2012
            • 296
            Originally posted by adriansto
            What machine ?
            Xerox C9070
            • PrintWhisperer
              • Feb 2018
              • 470
              Sorry, I definitely described that wrong and didn't think it through.
              When I said format that was in error. What I meant was remove any partitions on the drive.
              To format, you need to create a partition, so again sorry for your wasted time there should be no partitions on the drive.
              Are you sure the software is loading, as the LED must go through C1, C2, and other display numbers and not go straight to FF.
              • xcopytech
                • Aug 2006
                • 1794
                Do you have proper combination of service switches for usb dowload
                • Workflo
                  Veteran Member
                  • Apr 2021
                  • 5
                  There should be 2 Switches. The default position is to allow the controller to run 'Normally'.
                  Usually you'd switch both, if you were using an Ethernet load, or you'd switch one of them, to allow USB load.
                  Check the Guide, it should advise which configuration for Switches. (Also, not that it may show them upside down, so get up close and personal, so you can see which switch is which and get the setting right.
                  Once done, as it boots and loads, as @PrintWhisperer says, you should see the counter increase, as the SW successfully loads.
                  Best of luck!
                  • Reeves
                    • Apr 2012
                    • 296
                    At first I used fiery USB service tool when I drag and drop the files r not been copied the I used Rufus to copy files on the USB disk
                    • Reeves
                      • Apr 2012
                      • 296
                      Best of luck!
                      when reloading software on the fiery dip switch 1 ON dip switch 2 off that's what am doing
                      • Workflo
                        Veteran Member
                        • Apr 2021
                        • 5
                        @Reeves - Read the above....does this happen?
                        If not....
                        Make sure the USB is formatted correctly.
                        If Fiery USB Tool cannot load the USB Drive, then you may need a newer version (or maybe even an older version) of this software.
                        Once you have successfully loaded the SW onto the USB, THEN is the time to insert the USB, flip the correct DIPSW, power on and watch those digits do their thing.
                        A quick question....is this an EX , an EXI, or an EXC ?
                        • xcopytech
                          • Aug 2006
                          • 1794
                          Only way to create fiery usb is with usb tool.
                          You can not use any other software to copy files to usb.
